Import Point Cloud and Place mesh from Surveyors Data - Survey point alignment option missing!
Miha_M
As the Title says, I can't import a Point cloud or place a mesh from Surveyors data based on Survey point offset.
The Survey point functionality is not available in these import options; it should be.
It is not easy to bring in a point cloud into the same project file once you set the Survey point and change the north angle, but it could be so easy based on the Survey point coordinates and north angle, just like xref-ing a .dwg file.
1 Comment
Karel Landa
You can import point cloud based on survey point with BIMmtool add-on in LT version which is available for free with AC28 for free.
Nevertheless it shoould be native for both functions (import point-cloud/serveyors data) to have this checkbox.
Status
Open
with 7/200 Votes 28.571428571429%
Wish details
