In Archicad 28, managing layer visibility typically requires navigating through the Layer Settings dialog and manually toggling the visibility icons using the mouse. This process can be time-consuming, especially when working with projects that contain numerous layers.
Feature Request:
Introduce a keyboard shortcut functionality within the Layer Settings dialog that allows users to:
Quickly focus on the layer name input field.
Type the desired layer name to search and highlight it.
Use a specific key (e.g., Enter or Spacebar) to toggle the visibility (show/hide) of the selected layer.
This enhancement would streamline the workflow by reducing reliance on the mouse.
Use Case:
When working on detailed components, it's often necessary to temporarily display surrounding elements or specific layers for a particular construction step. Currently, this requires multiple mouse interactions to locate and toggle the desired layers, which can be time-consuming. Implementing a keyboard shortcut for this function would significantly expedite the process, enhancing productivity during detailed design tasks.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
