Kitchen Cabinet Opening Lines for Drawers
Sa_Chugg
I wish it was possible to show the following symbolic lines for drawers in elevation for Kitchen Cabinets (Base Cabinet Block):
  • lines to indicate drawer function (diagonal line or vee)
  • lines to indicate carcass location behind the front panel (including side panels, and shelves)
It seems the function was added to show symbolic lines for drawers in plan only?
3 Comments
I would love an option to have the shelf lines behind the cabinet doors show on the elevations just like the door swings do. This is a fairly standard graphic convention.
For now, i can try to make it work with a separate surface material that i can use Graphic Overrides to turn transparent, but that still would show a lot of busy linework for the carcasses behind.
Guru
Door lines can be turned on for the AC27+ kitchen cabinets within your MVO settings. It does not draw a line for drawers though...
I know about the door swing lines. My wish is for the lines of the inner cabinet shelves to be dashed in on the face of the cabinet in 2D elevation as well.
A workaround would be to get GO's to just change a single surface to transparent, but (at least in AC28), a GO rule cannot apply to a single surface material.
Status
Submitted
with 6 Votes
Wish details
