Mod files should not remember what was their source storey.
Why?
If someone uses the Iceberg Method, meaning the module is created in the source file on a negative storey,
if a new storey is inserted between 2 existing module storeys, the whole model gets messed up.
Creating modules in negative storeys may still be relevant even if Make Modules Great Again - 1: In Place Module Management was implemented.
Refer also:
Modules: required improvements
Make Modules Great Again - 2: Embedded Library Management
Make Modules Great Again - 3: Attribute Management
Make Modules Great Again - 4.0: Schedule Modules
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
