It is impossible to show the part of a stair that's above the slab, but hide the part that is underneath it. If you could choose to send the steps to front/back individually this would be solved.
@Barry Kelly, that's not what I meant. I want to see the top tread, but not the first step at the bottom because this step is hidden underneath the slab.
@Laszlo Nagy Performing a SEO with the stair as target isn't the solution as well.
I may have been unclear but I'm talking about the floor plan.
I want to have this result but without using fills:
@Barry Kelly I do want the top tread showing because it's a different material than the slab, like you see in 3D.
I gave the slab a fill, but that hides the top tread as well. The issue is that I want to hide the bottom tread because it's underneath the slab but show the top tread.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
