I would like to enter a wish about the appearance of stairs. I would like the option to make numbers/texts scale-sensitive (Model size) in the stair Settings. It is currently only possible to use fixed size (Paper Size) .
Not taking away from your wish as it may be valid to you.
But why would you want your text to print five time bigger?
I would always want the text to print at say 2mm no matter the scale, not 10mm.
If you want the entire drawing to re-scale, you can place the 1:100 view on a layout and then change the scale of the placed drawing to 1:20.
That will increase the text along with the stair.
And this will affect everything (all text) in that drawing including dimensions.
Not a good thing to do in my opinion, but may work for what you are trying to achieve.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 1 Vote
