I understand that this is likely a technically challenging request and that it may have been suggested before. However, I couldn't find it mentioned in this forum, so I am posting it here.
Feature Request:
The desired functionality is the ability to use multiple Floor Plan Cut Planes (FPCPs) within a single story. This would be particularly useful when working with projects that involve several building masses at different heights but require all of them to be displayed on the same layout.
Current Workflow:
At present, achieving this involves creating several views with different FPCP settings, each adapted to a specific height. These views then need to be combined manually on a layout to achieve the desired representation. This process can be time-consuming and error-prone.
Proposed Improvement:
It would be highly beneficial if Archicad could allow for the use of multiple FPCPs in a single view. This would streamline workflows, especially in projects with varied building heights, and would enhance the software’s flexibility in managing complex building representations.
Thank you for considering this suggestion.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
