Multiple Floor Plan Cut Plane per Story
Gortz
I understand that this is likely a technically challenging request and that it may have been suggested before. However, I couldn't find it mentioned in this forum, so I am posting it here.
Feature Request:
The desired functionality is the ability to use multiple Floor Plan Cut Planes (FPCPs) within a single story. This would be particularly useful when working with projects that involve several building masses at different heights but require all of them to be displayed on the same layout.
Current Workflow:
At present, achieving this involves creating several views with different FPCP settings, each adapted to a specific height. These views then need to be combined manually on a layout to achieve the desired representation. This process can be time-consuming and error-prone.
Proposed Improvement:
It would be highly beneficial if Archicad could allow for the use of multiple FPCPs in a single view. This would streamline workflows, especially in projects with varied building heights, and would enhance the software’s flexibility in managing complex building representations.
Thank you for considering this suggestion.
5 Comments
rakurs
Also, different FPCPs on a single view would be helpful with windows not being cut because of their sill height, without resorting to symbolic cut floor plan display for walls, as well as other types of overrides we have to use to show what we want on a floor plan. I mean, we CAN break section lines in floor plans, and FPCPs are conceptually lines on sections, so...
Professor Pickle
Yup. This has been asked for many times in the past. Basically what we want is not fixed idea of stories but arbitrary levels that can be defined in section. Let me decide which levels constitute a story, don’t force me.
Also, being able to define arbitrary levels really helps with designs that have mezzanines or any other kind of a split-level situation.
Also plan regions with diff cut planes.
MJScheltema
I'd like to add my voice to the chorus for this wish.
I would love to be able to have more flexibility on the Cut Planes. Regions would be ideal. Let me decide how I want my plans to be depicted.
Thanks for considering this request.
AngelWil
We need a way to Dynamically control the plan cut plane. We have building steps in many projects and stitching together plans views leaves room for error. Its also tedious to set up. I would think the best solution is using a similar tool to the section viewport that allows you to manually draw the level you want the cut to occur.
Space_Agency
I think @AngelWil has it: dynamically controlling the floor plan cut plane. And the interface for this needs to be dead simple. Something like selecting or creating a cut plane in 3d and push/pulling it to snap to something or dragging/moving it by a specified distance in the tracker, choosing a split axis line for the cut plan if desired and push pulling the plane that is split in relation to the other by push pull or tracker input as mentioned before.. I've seen similar done in other software and it's SO much simpler. The current method in Archicad is like navigating tax code and it rarely produces exactly what is expected or desired. It's another UI failure example that needs to be part of a basic UI review/overhaul in Archicad.
Status
Submitted
with 116 Votes
Wish details
Product
Labels
