It would be great to have a parametric extrusion object.
A few notes:
- The object could behave like a hybrid between the beam too and the Railing Tool.
- The railing tool is much too complicated for most simple extrusions, and the Column / Beam tools are artificially "limited".
- The tool should be parametric and allow you to select an complex profile, or draw a custom shape.
- The extrude path should allow multiple control points such as the railing tool, and allow you to "double back"
- The tool should allow curves
- Allow "SketchUp Style" Creation: Draw or select profile, select or trace path.
- The tool could be brought into the Morph tool (like the revolve construction morph) but should keep the control point history.
This was sparked by my need to create custom wall frames and the difficulty to doing so simply with reliable results.
