when dimensioning the room there is no adjustibility in the text dimensioning. In our case we wanted to add arrows closer to the dimension. In other cases you want to add sufixes to the dimension like the type of measurement(mm/cm/m).
when working with large amounts of measurements it takes a lot of time to change all to custom text. A "pre-pefined" pre- and suffix in the dimension tool would make it a lot quicker
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
