Project Info and Location Settings available for IfcSite and IfcBuilding custom property mapping
Mikko Lahti
It would be great if Project Info (with custom fields) and Location Settings (including the new Survey Point coordinates and Project North) would be available for custom ifc property mapping.
In Finland, new legislation for applying building permit electronically mandates the use of certain custom property sets and properties in the ifc file to be submitted to the authorities. They include stuff like Site Address, Contact details, World Coordinate values etc. The properties are mostly required in the IfcBuilding entity level, plus a few in the IfcSite. We are supposed to use a precisely defined naming format for the custom ifc property sets and properties, so that they can be automatically processed in the receiving end.
Since most of these are already present in Project Info and Location, it feels silly that we now only seem to be able to do this by manually adding these properties or via a third-party solution such as BlenderBIM or Simplebim.
3 Comments
MaFarine
Yes please!
There are more and more requirements at these levels (Project, Site, Building, BuildingStorey) and we don't want to put values manually in the IFC Manager.
abdelaziz
Hi
please we don't want to do the work twice this feature should be a priority as it directly impacts workflow consistency
James B
Status changed to: Under consideration
Moved to under consideration, as we work on improving Project Info - as indicated here on our road map: https://community.graphisoft.com/t5/Product-Roadmap/Flexible-Project-Info-organisation/idi-p/659688
Status
Under consideration
with 29 Votes
Wish details
