Currently, if a fill is set to display the fill area, the area text properties omits the standard text frame / opaque background offset parameter applying to other ArchiCAD text.
This prevents graphically important clear space displaying around the area text in the way that it does for all other text, and means that text characters with descenders (such as lower-case g) actually extends through the frame or across the edge of the opaque background.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
