Publish Layouts Settings - Flat PDF, setting dpi of image formats
2D
Setting whether a PDF should be exported flat or rasterized should not require external applications. Currently, PDFs generated by Archicad are still very hard to view or work with in other applications and by different parties.
Similarly, the publishing image formats from the layouts should give the user much more control over the generated quality of the image, not using a slider which has little to no influence on the generated content but by usual means such as setting the DPI.
1 Comment
Status
Open
with 20/200 Votes 10%
Wish details
