Window dpi setting
2D
Having the possibility to control the window dpi setting globally would allow for a more consistent workflow. This would allow controlling and setting the export quality of images from an Archicad window across all Archciad windows in a file.
At the moment, this can be achieved by setting the window size, which is a workaround, not a solution.
Set Resolution for 3D Views - Graphisoft Community
1 Comment
Karel Landa
I think that what you asking for is already on Roadmap in "In progress" section here. 😉
Status
Submitted
with 0 Votes
