Reference Levels (Non-Story Levels for Better Model Control)
Pedro Melo
It would be extremely helpful to introduce the concept of Reference Levels in Archicad — similar to Revit’s Levels — which are non-structural, non-story markers used to define key vertical positions in a model (e.g. ceiling heights, parapets, window datum lines, etc.).
These levels would not function as actual stories, and would not be exported as separate floors in IFC, but would provide a consistent and visible reference for modeling and coordination.
Proposed Implementation:
  • Add a new category of levels in the Story Settings dialog, called Reference Levels
  • Reference Levels would:
    • Appear in Section/Elevation views with custom markers
    • Be usable as snapping and alignment guides
    • Be selectable in element settings (e.g. set top of wall or beam to “Ceiling RL +2.7m”)
    • Not generate story markers or impact IFC story structure
    • Have their own layer or visibility control
Optional extras:
  • Reference Levels could be grouped (e.g., Ceiling Levels, Façade Datums)
  • Could be color-coded or styled differently from real stories
Why This Is Important:
  • Improved Coordination: Ceiling levels, bulkhead lines, parapet heights, etc., can be defined and referenced clearly, without cluttering the Story structure or requiring dummy stories.
  • Cleaner IFC Export: No need for fake stories that confuse consultants or clash with structural models.
  • More Accurate Modeling: Allows modeling elements like walls, ceilings, and beams in relation to a defined height, not just the nearest story or manual height input.
  • Industry-Standard Workflow: This aligns with how many multidisciplinary teams work — especially when integrating with Revit-based consultants.
Example Use Case:
In a commercial building:
  • Ground Floor is at 0.00
  • Ceiling RL at +3.200
  • Bulkhead RL at +2.600
These are critical modeling guides, but don't warrant actual stories. Currently, workarounds like 2D lines or fake stories are used, which are not robust or parametric.
22 Comments
Rve
@Botonis
Thank you for the info. That sounds very usefull.
I can't find any video's about it on Youtube. Could you record a small video to show how is works?
Botonis
Mentor
Just uploaded a video to show how easy it is to add additional story levels.
And those settings are integrated inside the story marker. Not an object.
You can have a favorite section marker saved for every case with additional stories or settings.
VIDEO STORY MARKER
Status
Open
with 103/200 Votes 1.941747572816%
Wish details
Labels
