Renovation tool needs to be updated
Mr Tomescu
The Renovation tool is very useful and powerfull, but it has major drawbacks.
1. Solid Elements Operations dont interact properly with Renovation. If you have a New element thad gets substracted from a Existing one, the operation appears in the Existing Elements filter combination as well, wich is wrong (ex. a new wall that gets substracted from the ground mesh. the hole created in the mesh is visible in the existing status as well).
2. Composites layers dont combine well with Renovations. You may have a existing wall that just has a new layer added (thermal insulation, structural grouting etc.). This cannot be achieved in a BIM way currently. You have to add extra individual walls adjacent to one another to obtain this.
3. Surfaces and Renovations dont work together. You may have a existing wall that gets a new finish. You cant obtain this in a BIM way usig Renovations. You can work around it with Graphic Overrides, but thai is not the point.
The list may go on.
Please update the Renovation tool
Thank you.
2 Comments
DMP33
Added a vote here because I am running into the issue of wanting to use SEO for a proposed cut into an existing ground mesh, but the cut is showing in both Existing and New renovation filters.
bauart
Added a vote here as well: This is essential for renovation project to have more control on separate layers of composite elements without remodel entirely separate elements
Status
Open
with 24/200 Votes 8.333333333333%
Wish details
Product
Labels
