Renumbering door and windows numbers in large projects
Andrew Reynolds1
Re-numbering door numbers, window number and furniture in large developments.
With large buildings doors and windows numbers that require renumbering to be sensible can be time consuming at early Tender stages, as can be furniture? Can this be done by selecting the doors and numbers, drawing a path start and finish on screen and adding a starting character such as 'W', 'D', 'W-100' or 'W-00..' user specific. can this be another tool? Door numbers are usually sensibly numbered clockwise or anticlockwise from a start point on the drawing.
1 Comment
Karel Landa
I agree with this wish as it should be easier for the user to automatically number any set of objects.
But for now you can either use ID manager, which can do what you are asking for but it is "random"
Or you can follow steps in the "tip of month" article which is using pythong and tapir add-on an you can draw a polyline and decide, how the numbering goes.
Status
Submitted
with 2 Votes
