Re-numbering door numbers, window number and furniture in large developments.
With large buildings doors and windows numbers that require renumbering to be sensible can be time consuming at early Tender stages, as can be furniture? Can this be done by selecting the doors and numbers, drawing a path start and finish on screen and adding a starting character such as 'W', 'D', 'W-100' or 'W-00..' user specific. can this be another tool? Door numbers are usually sensibly numbered clockwise or anticlockwise from a start point on the drawing.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
