Save criteria sets in graphic overrides and schedules
lutz
when creating a schedule, i like to have a drawing which shows which elements are taken into account in the schedule.
for example if i have a schedule that shows the m2 of the north fassade of a project, i want to show a 3d view of the project, highlighting this north fassade.
I use this to check if my criteria set for the schedule is correct (for example if  the interior walls are highlighted too, i know i need to refine the criteria).
At the moment i have to create the criteria set twice - once for the schedule and once for the graphic override, which is error-prone.
It would be nice if it was possible to save the criteria set and use it in the graphic overrides and the schedules. I know it is possible to save a criteria set in the find-and-select tool, so hopefully it is possible to make this accessible from graphic overrides and schedules as well.
1 Comment
If you generate the Schedule, and with nothing selected, click the "Select in 3D" button, then the 3D Viewpoint will appear and all elements listed in the schedule will be selected (provided they are visible due to layers, etc.)
Status
Submitted
with 6 Votes
Wish details
Product
Labels
