Specify measurement display formats (specifically SF instead of sq ft)
MarthaKay
Ability to change the global project settings for area unit abbreviation from "sq ft" to "SF." This setting should apply to Zone Stamps, Schedules, Fill Areas, etc. There are several community threads with workarounds for this issue. However, none of them apply globally, and many require editing GDL scripts. This should be a built-in option in Archicad.
1 Comment
James B
Thanks for the feedback. New in Archicad 29, now in schedules you can turn off the previously always visible units, and can add your own custom prefix or suffix (ie unit display).
For more information refer to:
https://help.graphisoft.com/AC/29/INT/index.htm#t=_AC29_Help%2F005_NewFeatures%2F005_NewFeatures-21....
Status
Open
with 5/200 Votes 40%
