Specify measurement display formats (specifically SF instead of sq ft)
MarthaKay
Ability to change the global project settings for area unit abbreviation from "sq ft" to "SF." This setting should apply to Zone Stamps, Schedules, Fill Areas, etc. There are several community threads with workarounds for this issue. However, none of them apply globally, and many require editing GDL scripts. This should be a built-in option in Archicad.
2 Comments
James B
Thanks for the feedback. New in Archicad 29, now in schedules you can turn off the previously always visible units, and can add your own custom prefix or suffix (ie unit display).
For more information refer to:
https://help.graphisoft.com/AC/29/INT/index.htm#t=_AC29_Help%2F005_NewFeatures%2F005_NewFeatures-21....
Darren_Kilker
@James B, That is great that it is an option in schedules, but what about everywhere else sq ft shows up such as zone and fill related notations?
Status
Submitted
with 6 Votes
