Ability to change the global project settings for area unit abbreviation from "sq ft" to "SF." This setting should apply to Zone Stamps, Schedules, Fill Areas, etc. There are several community threads with workarounds for this issue. However, none of them apply globally, and many require editing GDL scripts. This should be a built-in option in Archicad.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
