Suppress pop-ups
waydowntown
An override to suppress pop-up warnings. In our case it relates a large project file with hundreds of external links on a drive that was no longer accessible. Opening the Archicad file would require cancelling many pop-ups warnings.
2 Comments
Not a good idea to turn the warnings off, as you may not notice there is a problem.
It would be nice to say 'Skip All' for similar messages, although you can just 'Cancel'.
Then fix the problem and you should have no more messages.
Does the Work Environment for messages work for you?
You can turn messages off in there.
Again, it is not a good idea.
This is an image from 22, but it is similar in all versions.
@waydowntown,
Can you post a screenshot that shows the type of pop-ups that appear that you wish to globally suppress?
Status
Submitted
with 0 Votes
Wish details
