wishing for a way to find and select or highlight (on screen view options?) static dimensions in a given viewpoint
You can use Find & Select.
Or you can set up a Graphic Override rule.
It will select/highlight the entire dimension, not just the static part.
Is this what you are after?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 1 Vote
