Farah Bazian
since ‎2020-06-25
‎2024-02-19
User Statistics
  • 3 Posts
  • 0 Solutions
  • 0 Likes given
  • 0 Likes received
User activity
There is a common issue about Archicad-Revit interoperability regarding Door swings as they aren't displayed correctly in Revit most of the time. We have already had several discussions about this topic and we have found some useful workarounds that can be shared. Hopefully,...
Open & Repair is one of the most useful commands in Archicad, it is the solution to many common issues. The purpose of the repair process is to physically fix damaged files. When the damage occurs, one or more parts of the file become corrupted or lost. The Archicad Plan Fil...
by Dwight Atkinson, Vancouver, Canada Creating wall openings as windows is not the easiest or fastest way to make design experiments with wall openings. For non-critical work, using an SEO (=Solid Element Operation) combined with a Complex Profile Beam is faster and more ada...
