2024-02-05 08:15 PM
Hi, as mentioned in the topic, i couldnt start the ai engine, just saw an error message in the windows cmd:
fatal: detected dubious ownership in repository at 'C:/sd.webui/webui'
'C:/sd.webui/webui' is owned by:
'S-1-5-32-544'
but the current user is:
'S-1-5-21-265107965-60539204-3341374392-1001'
and at the end:
RuntimeError: Couldn't fetch Stable Diffusion.
Command: "git" -C "C:\sd.webui\webui\repositories\stable-diffusion-stability-ai" fetch --refetch --no-auto-gc
Error code: 128
The whole installation went succesfully, i can see the add-on in my archicad 27. I also tried to reinstal the whole thing and set sd.weiui folder properties to allow modification for all users. Unfortunatelly nothing happened.
Since I am not an IT guy, I have run out of ideas ://
Any ideas how to solve this problem?
My computer:
Win 11 Pro 22H2
i7-13700KF
NVIDIA RTX 4070 Ti
32 GB RAM
2024-02-07 08:55 AM
Hi BK,
Thank you for the information.
This seems to be a file ownership error. Is it possible that you moved the unzipped folder between locations with different permission settings?
Please make sure to unzip the folder at the C: root folder and run Archicad in admin mode.
If it does not help, please share the full content of the Command Prompt window with us.
Kind regards,
Technical Support Engineer
