Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI Engine Start failure
BK
Hi, as mentioned in the topic, i couldnt start the ai engine, just saw an error message in the windows cmd:
fatal: detected dubious ownership in repository at 'C:/sd.webui/webui'
'C:/sd.webui/webui' is owned by:
'S-1-5-32-544'
but the current user is:
'S-1-5-21-265107965-60539204-3341374392-1001'
and at the end:
RuntimeError: Couldn't fetch Stable Diffusion.
Command: "git" -C "C:\sd.webui\webui\repositories\stable-diffusion-stability-ai" fetch --refetch --no-auto-gc
Error code: 128
The whole installation went succesfully, i can see the add-on in my archicad 27. I also tried to reinstal the whole thing and set sd.weiui folder properties to allow modification for all users. Unfortunatelly nothing happened.
Since I am not an IT guy, I have run out of ideas ://
Any ideas how to solve this problem?
My computer:
Win 11 Pro 22H2
i7-13700KF
NVIDIA RTX 4070 Ti
32 GB RAM
1 REPLY 1
Norbert Kucsma
Hi BK,
Thank you for the information.
This seems to be a file ownership error. Is it possible that you moved the unzipped folder between locations with different permission settings?
Please make sure to unzip the folder at the C: root folder and run Archicad in admin mode.
If it does not help, please share the full content of the Command Prompt window with us.
Kind regards,
Norbert Kucsma
Technical Support Engineer
