Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI VRAM memory issue
SPIROS VOUTSELAS
Hi all.
My CPU spec are the following:
NVIDIA Quadro RTX 4000 8 GB Vram
64 GB RAM
i7 10th gen CPU
Windows 11.
When running the AI Visualizer I always ( even in a simple mode - 1 cube and a slab for base ) I always get an error message probably regarding the Vram .
I also tried the " start in hight Vram " - checked and unchecked - option  - Any suggestion ?
Thank you in advance
2 ACCEPTED SOLUTIONS
Norbert Kucsma
Hi Spiros Voutselas,
Thanks for the question.
I suspect the engine is still in HighVram mode, please try the add-on in low Vram.
On the AI Visulaizer UI:
- stop the engine (the button next to the 'Start AI Engine') and wait a minute
- uncheck the 'Start in High Vram mode' checkbox
- Start AI Engine (and wait for it to start)
- generate a picture
In case it still fails, please contact your local support and share the content of the Command Prompt window as well.
Thank you,
Norbert Kucsma
Technical Support Engineer
SPIROS VOUTSELAS
Hi Norbert. Yes you have right . It worked. I was doing the same but without  restarting the engine. All good. Thank you very much !!!!
4 REPLIES 4
Norbert Kucsma
Thank you,
Norbert Kucsma
SPIROS VOUTSELAS
ryejuan
Hi I was testing around the Ai Visualizer but am encountering this kind of error any ideas what's causing it?
Thanks!
In the end what is your Objective?
ArchiCAD 9 onwards
this one worked if you unchecked the high vram mode. 😁
ArchiCAD 9 onwards
