Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI engine crash
Mboro
Hey
i have this issue when running run.bat. any ideas how to get this going ?
'environment.bat' is not recognized as an internal or external command,
operable program or batch file.
Couldn't launch python
exit code: 9009
stderr:
Nie mo
Launch unsuccessful. Exiting.
Press any key to continue . . .
1 REPLY 1
Norbert Kucsma
Hi Mboro,
Thanks for the question.
I suspect that you did not unzip the sd.webui folder to the C:\ root location. Please try to unzip it again to the correct folder.
If it still fails please contact your local support with the content of the Command Prompt window and a few screenshots.
Kind regards,
Norbert Kucsma
Technical Support Engineer
