Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
SOLVED!
When hit Generate - AI Visualizer get message - Image generation failed - no server
Kiro
No connection to the Server.
Message when begin AI generation.
I put IP address: 127.0.0.1:7860
The screen shot is in the attachment.
Thanks in advance for your help to sort out this problem.
1 ACCEPTED SOLUTION
Solution
Norbert Kucsma
Hi Kiro,
Thanks for the question.
I suspect that the engine is not running. Please click on the Start AI Engine (and wait for it to start) then try to generate an image.
In case it still fails, please contact your local support and share the Command Prompt window output as well.
Kind regards,
Norbert Kucsma
Technical Support Engineer
1 REPLY 1
Solution
Norbert Kucsma
Hi Kiro,
Kind regards,
Norbert Kucsma
