This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-25
12:00 AM
2023-11-27
08:27 AM
Noemi Balogh
No connection to the Server.
Message when begin AI generation.
I put IP address: 127.0.0.1:7860
The screen shot is in the attachment.
Thanks in advance for your help to sort out this problem.
Solved! Go to Solution.
2023-11-27 11:20 AM - edited 2023-11-27 11:21 AM
Hi Kiro,
Thanks for the question.
I suspect that the engine is not running. Please click on the Start AI Engine (and wait for it to start) then try to generate an image.
In case it still fails, please contact your local support and share the Command Prompt window output as well.
Kind regards,
Technical Support Engineer
Hi Kiro,
Kind regards,
