2023-11-22 12:25 AM
Once you've experimented with various alternatives, is there a way to take back one of the "seeds" that AI has used previously? Or is "Lock result" the only way and it is therefore necessary to produce all the Archicad desired views from different angles to avoid losing the alternative?
