This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-12-11 12:59 AM - last edited on 2023-12-11 11:30 AM by Noemi Balogh
I wanted to use Ai Visualizer on a computer that meets minimum system requirements (NVIDIA cards with 8GB VRAM and 32GB RAM)
(My computer: NVIDIA GeForce RTX 3070, 8 VRAM and 32GB RAM).
I copied sd.webui folder into the C:\ root folder, Add-ons folder into the Archicad folder, installed Python 3.10.6, and the "run" file from sd.webui folder ran as administrator. It took a couple of minutes, but it did not show any kind of error.
After that, I opened Archicad 27, made a simple model, set the image size to the lowest, and turned off "Start in Hign VRAM Mode".
When I click "Start AI Engine" it does not show any kind of error.
But when I want to generate the model "image generation" fails.
In the server window it shows the next error:
Does anybody know how to fix the problem?
Thank you in advance!
Operating system used: Windows 11 22H2
2023-12-11 11:12 AM
Hi Andtop,
Thank you for the detailed description.
The Add-on should work after the troubleshooting steps you made. The error indicates a your PC runs out of memory, please close any other apps running in the background and try again.
If it still does not work, please contact your local support, and we will investigate your issue.
Kind regards,
Technical Support Engineer
2023-12-11 12:30 PM
Hello
I am using brand new computer, that does not have any apps on it yet. So the only app that was running was Archicad.
I already contacted my local support (PILON AEC d.o.o.) and they could not help me with my issue.
I would be very pleased if you could help me with the issue of mine.
Kind regards.
