2023-11-17
10:10 PM
- last edited on
2023-11-18
02:01 AM
by
After dragging run.sh it to the Terminal window and hit Enter, this message shows up in HomeBrew / Terminal.
I have moved the AI Visualizer folder from Add-ons into Archicad 27 folder > Add-ons > Extra.
And i have moved the sd.webui folder into Archicad 27 folder.
2023-11-23
05:37 PM
- last edited on
2023-11-26
06:39 PM
by
2023-11-24 01:43 AM
@iggiv wrote:
- When prompted to insert my password, a "gray key" icon appeared, and I am unable to type the password.
Ah, I see, you have encountered a very common 'strange' behaviour of the password prompt in Terminal: no symbols are echoed.
This means that when you type your password, you do not see any input by design.
So, to solve a problem with password entry:
2023-11-24
04:39 AM
- last edited on
2023-11-26
06:46 PM
by
GAG:
Thank you very much for trying to help. Your assistance is appreciated.
Yes that work to install the BREW. I then continued by drawing the "run.sh and got the ERROR: python3-venv is not installed, aborting? But do not know what to do next!!!
2023-11-24 10:10 AM
@iggiv wrote:
GAG:
Thank you for your kind words!
After installing the brew package manager, you should install the required dependencies.
The idea is to install brew as a first step, and then install other packages via brew as a second step.
So, in the Terminal run the `brew install` command with package list as a parameter:
brew install cmake protobuf rust python@3.10 git wget
In the above command:
If you get an error that `brew` is unknown, then run the same command but with the full path to brew:
/opt/homebrew/bin/brew install cmake protobuf rust python@3.10 git wget
Where:
After running the above command, you'll have all the necessary dependencies installed.
Only then can you proceed to execute `run.sh' in the 'sd.webui' folder.
2023-11-24 12:29 PM
Dear GAG,
Good morning and, thank you very much once more! I just want to make sure as I do not understand what I am doing. I followed the steps above, and this "brew" WAS INSTALLED. I then executed the first command:
It didn't seem to do much, so I proceeded with the second command:
Voila! It started processing, and the screen is moving forward. I am now like a kid at Christmas! However, I am not sure if I should close the terminal. It is unclear if the process has not been completed. If I try to close it, I am asked if I want to terminate the process, which I do not want to do until it is done. What should I do next? It seems like this will be the last step before trying to do my first visualization, and I can't wait to b that!
Thank you for your guidance. I will try to wait for your response, but I am not closing anything for as long as I can.
Best regards,
2023-11-24
12:34 PM
- last edited on
2023-11-26
06:49 PM
by
Dear GAG: I N C R E D I B L E !!!
I could not wait so this is what I did.
I quit AC where I was working and reopened. Then open the visualization pallet and try my first test with AI Visualizer!!!
IT WORK!!!
Thank you very much and apologies for all of the confusion. I know can close the terminal!!!!
2023-11-24 01:26 PM
Awesome! I am so glad that you have finally managed to complete the installation and get your first results!
As a token of appreciation, you can 'like' my posts that have helped you 😉
2023-11-28 11:56 AM
Hello, thank you for your help, I have the same problem with an error (python3-venv is not installed). What can I do ?
2023-11-28 03:52 PM
Please, answer the same questions that I have asked in this post.
Your terminal log shows that you don't have Python installed.
2023-11-28 04:07 PM
Hi, I have the same problem (python3-venv is not installed)
And yes I have followed the installation instructions, installed brew package manager and also installed all other required packaged.
Is the problem as simple as a restart required?
