on
2024-02-28
02:43 PM
- edited
Wednesday
by
Emoke Csikos
This article below will guide you through the uninstallation process of the Legacy AI Visualizer Add-on for Archicad 27 on Windows and MacOS.
The Archicad AI Visualizer is our AI-driven image generation tool. Powered by Stable Diffusion, you can use it to create impressive, detailed 3D visuals in the early design stage without needing a complex model.
From Archicad 28 AI Visualizer is built into Archicad as a cloud-based solution and it does not require a separate installation. This new version is available to users with an Archicad Collaborate or Education license. To learn more about this tool, please visit our dedicated webpage, and knowledge base article.
Please note that the legacy experimental version of the AI Visualizer for Archicad 27 reached its end of service on December 31, 2024, meaning that it no longer receives updates or support. The rest of this article is about the legacy version.
Archicad 28 does not support the legacy version.
Are you experiencing issues with installing or running the Archicad AI Visualizer Add-on? It might be worth reinstalling the Add-on and getting a fresh start.
The article below will guide you through uninstalling the Legacy AI Visualizer Add-on for Archicad 27 on Windows and MacOS.
A simple, two-step process. Just delete:
Uninstalling the AI Visualizer Add-on on Mac is more complex, please carefully follow the instructions below carefully.
If you installed Homebrew and the Python packages together with the Add-on (and did not have them installed before), follow these steps first:
Now it’s time to uninstall Homebrew and the Python packages. To do this, please open Terminal and run the command:
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/uninstall.sh)"
An option will appear in the Terminal window. Select the “y” option by simply entering y and hitting enter.
You will see the following:
You will be asked to enter the admin password to allow the changes. Please type in your password.
Then you will see the following:
This means that some folders have not been deleted yet -- all of the remaining folders will be listed here. Go ahead and manually remove the "/opt/homebrew /" folders and files.
Please note that the /opt/ folder is hidden by default. Use the ‘Cmd+shift+.’ shortcut to show hidden folders.
If you already had Homebrew and some Python packages installed before installing the AI Visualizer Add-on.
