2024-01-06 04:37 PM - edited 2024-01-06 04:42 PM
Hello everyone and sorry for my english,
Like many of you, I am faced with the following error message:
I have the following configuration:
Windows10 up to date
Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz 12 cores
64G DDR
NVIDIA P4000 8G VRAM (driver 546.01)
Archicad 4030 FRA full
What's strange is that the local server is working and I can generate images via the prompt:
So the problem would be the link between archicad and the local server?
I tested with AC as administrator, with and without Avast activated, I installed the latest version of Python and nothing works.
2024-01-07 09:19 AM
It looks I have the same problem :
Any idea ?
32 RAM 4 VC, Xenon
2024-01-28 12:25 AM
Hello, I have the same problem with it. I don´t know how to fix it. Have anybody an idea?
2024-02-01 10:33 AM
Hi Kris K,
Thank you for the screenshot.
Please let us know what type of video card you have, and how much VRAM. Also, a full content of the Command Prompt window would be useful too.
Kind regards,
Technical Support Engineer
2024-02-01 10:37 AM
Hi Ab-Project,
Thanks for the information.
According to your screenshot, we suspect that this is a custom installation. The "hand_refiner_portable" folder/location seen in the error is not a part of our Add-on.
You don't need the Stable Diffusion browser for our solution. Please try to install the Add-on again from scratch.
Please send us the Command Prompt window content after the error message appears in Arhicad.
Kind regards,
