Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
Sorry, we could not generate the image - Cuda out of memory.
Paullalor
ArchiCAD 27 Windows user.
I've copied the sd.webui to the root folder C:\sd.webui.
I've copied the add-ons folder in my ArchiCAD folder.
I prepared a simple 3d model to render.
I keep getting the attached "Cuda out of memory" error message. I've tried this on two different computers and keep getting the same messages. Please see the settings and error message attached.
I've stopped the engine. Waited a while. unticked the "Start in High VRAM mode". Then clicked the Start AI Engine however I still got the same error message.
Can someone please help as I really want to get this working.
Thanks
1 REPLY 1
Lingwisyer
Guru
You know, you should probably include your system information in your signature. From the error report, you are using a 6GB GPU, the minimum requirement is 8GB, whislt the recommended is a 16GB card...
AC22-28 AUS 3001Help Those Help You - Add a Signature
