Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
Sorry, we could not generate the image. The ai server is not available
jurekwichlacz
As you can see I have a problem with ai visualizer. When I'm trying to generate the photo, I get this message that ai server is not available.
6 REPLIES 6
Pawel Spychala
Graphisoft has limited the use of AI visualizer to educational licenses and subscriptions - they don't give a damn about perpetual license holders.
If it was a license issue, the error message would say 'no license available'.
Seems strange the autor has got this far if it is a license issue.
@jurekwichlacz , do you have a collaboration subscription or an SSA/Forward support agreement?
I am assuming this is 28 or are you using 27.
27 is built into the program so there should be no issue.
28 uses the cloud to process hence the error - just may not be available at that particular time.
I’m using 27 version on educational license, so everything should work correct.
Thanks for that.
Yes, it should be working correctly.
I have no idea why the server would not be accessible.
I believe in 27 it only works with certain hardware - NVIDIA video cards on Windows machines.
In version 28 it is all done in the cloud, so you don't need specific hardware.
There has been an update for Visualiser in 27.
https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC28_Help%2F070_Docum...
Does this help?
jurekwichlacz
No, nothing helps.
Setup info provided by author
