2024-07-19
01:18 PM
2024-07-23
02:39 PM
After installing, throw the "AI_Visualizer-Installation_Guide"
i have an issue after running "run.sh"
The Command stops with the Prompt:
Please use pip<24.1 if you need to use this version.
ERROR: Could not find a version that satisfies the requirement torchsde==0.2.5 (from versions: 0.2.5, 0.2.6)
ERROR: No matching distribution found for torchsde==0.2.5
Has someone a workaround for this?
2024-07-20 07:18 PM
I have the same issue
2024-07-25 11:35 AM
same problem
4 weeks ago
Hello, I have the same problem!
3 weeks ago
Same thing here, did you find a solution?
3 weeks ago
I have exactly the same problem. If you edit the 'version requirements' .txt file so the script looks for torchsde 0.2.6 instead, you just run into a different error:
from pkg_resources import packaging
ImportError: cannot import name 'packaging' from 'pkg_resources' (/opt/homebrew/lib/python3.10/site-packages/pkg_resources/__init__.py)
It would be fair to say that AI Visualizer is bricked software until this issue can be resolved.
2 weeks ago
Hi all,
We apologize for the delay and any inconvenience this may have caused. Unfortunately, the current macOS installer for AI Visualizer is not functioning properly. Our developers are actively working on a solution.
If installing the AI Visualizer is critical for your business, please reach out to your local technical support for assistance.
We appreciate your understanding and patience as we work to resolve this issue.
Kind regards,
Technical Support Engineer
2 weeks ago
Thanks for your answer Norbet!!! How we would be notice when it would be fixed? Cheers
Wednesday
Hi Norbert!
Any update on this subject ?
Wednesday
Hi Piotrihnat,
Thank you for your patience. We're actively working on a solution, and we hope to have the install package fixed in the coming weeks.
Sorry for the inconvenience.
Kind regards,
