I've done some tests
I think it's worth the use
Hey Scoz! Amazing results again! AI Visualizer is not even optimized for interior use, yet you still created amazing variations! Great work! ^^
Pretty awesome. I suspect that the "Maintaining the basic form" part of the prompt is important here.
Hi @scoz,
Very nice results, indeed! Did you use the experimental PBR to use it as an input image prompt?
This is a result from the NVIDIA RTX(5000Ada) basic setup.
I think AI Visualizer is very smart.
Among the current projects, one part of the interior on the first floor is an AI Visualizer
I did modeling.
AI Visualizer is better than most rendering programs in controlling light
@scoz Again,really nice concepts, inspirational sources from just an empty space! Well done!
@scoz really interesting work!
@Illes Papp how can one use the experimental PBR as an input image prompt, like you mention above?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
