We value your input!
Archicad C++ API
AC17 API - ACAPI_3D_GetCurrentWindowSight
ACAPI_3D_GetCurrentWindowSight parameters have changed from *short to **void. With AC16 a -1 short was return for non-3d sights. What is returned in the void** in AC17 for non-3d sights? Documentation provides no clues. (And I don't have AC17 yet to find out!).
Thanks in advance.
10 REPLIES 10
PBartke
Graphisoft Alumni
Graphisoft Alumni
You should check the return value of ACAPI_3D_GetCurrentWindowSight before using the sight. In case of non-3d sight it will return APIERR_BADWINDOW I think. The void** parameter won't change.
Thank you.
Another sight question.
AC16 had a function Modeler::Sight::GetSightPtr (currentWindowSightId) so you can get the SightPtr for the ACAPI_3D_GetCurrentWindowSight.
This call (GetSightPtr ) is no longer present in the AC17 API - how can I achieve the same outcome as in AC16 pls?
Thanks
In addition to the above, is ACAPI_3D_GetCurrentWindowSight actually returning a pointer to a Modeler::SightPtr now (int he form of a void **)? Any details on this appear to be absent from the AC17 API documentation.
Thanks
To save others some time working this out....the void** returned by ACAPI_3D_GetCurrentWindowSight appears to be in fact a Modeler::SightPtr, so it is possible to do the following:
	Modeler::SightPtr currentSightPtr;
	GSErrCode err = ACAPI_3D_GetCurrentWindowSight ((void**)&currentSightPtr);
Perhaps this is not in the doco because Modeler::SightPtr is undocumented.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
here's a short example code to show how to use ACAPI_3D_GetCurrentWindowSight (and EXPGetModel which has been changed in AC17 API also).
       GSModeler::ModelFuncTable *funcTable = EXPGetModelFunctionTable ();
       if (funcTable == NULL)
             return APIERR_CANCEL;
       GSModeler::Model::SetFuncTable (funcTable);
       void*  currentSightPtr;
       if (ACAPI_3D_GetCurrentWindowSight (&currentSightPtr) != NoError)
       GSModeler::Model model;
       Modeler::Sight* sight = static_cast<Modeler::Sight*> (currentSightPtr);
       if (EXPGetModel (sight->GetConstMainModelPtr (), sight->GetSunSettings (), &model) != NoError)
Regards,
Tibor
drjustice
I would like to confirm that the code posted by paulk is indeed incorrect.
A Modeler::SightPtr happens to be a GS::SharedPtr<Sight>, which is not the same as a raw Sight* pointer.
Calling the code above will seem to work but in fact will produce memory corruption errors that are difficult to track.
Tibor's answer is better, although I have fixed my problem differently:
        void* dummy = nullptr;
        ACAPI_3D_GetCurrentWindowSight(&dummy);
        Modeler::SightPtr currentSightPtr((Modeler::Sight*)dummy); // init the shared ptr with the raw pointer
        ModelerAPI::Model acModel;
        AttributeReader attrReader;
        EXPGetModel(currentSightPtr, &acModel, &attrReader);
You are responding to an 8 year old thread... is your comment really about the AC 17 devkit / API ... or about a more recent version?
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
drjustice
I am working on Archicad 24/25 plugin.
And I'm sorry about reviving this. I replied because I always assume that if I struggle with something, then others are likely to eventually struggle with it also.
And whenever I post questions, if I don't get answers and I eventually figure it out, I will post an answer online to my own question -- again for the same reason.
I could be lazy and just leave the thread unanswered with no solution (as many threads here seem to end up) but I actually take the time and make the effort to give back to the community.
BTW, I know it's unproductive to complain. But I wish the Archicad API was well documented, but alas this isn't the case most of the time.
Like, I don't understand why you have 12 different data structures that do the same thing, in different namespaces, some types that are classes but some that have constructors some that don't, some that use void pointers, some that use templates, some type names that are missing letters, some that you must initialize not with a constructor, but with BNZeroMemory, and that the SDK provides header files that are there for whatever purpose but that we're not allowed to use other than to make things compile, some classes that we are allowed to use but when you call some of their methods you get unresolved externals, and so on...
