Archicad C++ API
AC18 DevKits are available
Akos Somorjai
Hi fellow developers,
The ArchiCAD 18 API development kits are available in the download area. Don't forget to read the New Features Guide
Good luck,
Ákos
27 REPLIES 27
Thanks Ákos
I am getting a compilation error in my plugin because all the files from C:\Program Files (x86)\Graphisoft\API Development Kit 17\Support\Modules\GSModelDevLib\Sources are missing in the AC18 API.
Paul
Akos Somorjai
paulk wrote:
Thanks Ákos
Paul
Hi Paul,
Please remove those .cpp files from the project; from AC18 they are compiled into GSModeler.dll/.framework.
Regards, Akos
Thanks Akos
There are a lot of changes not documented. For example, GSModeler replaced by ModelerAPI. And some documentation does not match the header files - DGSetItemImage for example. Plus changes to AppendToLocal, etc etc. There is really a lot of work to update plugins to run under AC18.
Paul
Another example - DGModalDialog - the documentation does not match DG.h.
I think there is a bad bug in the new AC 18 API. It looks like material GUID's are always returned as null. See the image below. Is there a workaround for this? We need to have unique ID for each AC material object. This works fine in AC 17 as you can see in the image.
Thanks
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Dave,
Unfortunately it's a known bug, we will fix this in the next AC18 hotfix update.
Regards,
Tibor
Hi Tibor,
Okay thanks for that.
Regards,
Dave
Hi
I am unable to get my addin to link for AC18. The same project links fine for AC17. The link error is:
1>SettingsDialog.obj : error LNK2001: unresolved external symbol _Inf
I am linking the following libraries:
ACAP_STAT.lib
DGGraphixImp.lib
DGImp.lib
GraphixImp.lib
GSModelerImp.lib
GSRootImp.lib
GSUtilsImp.lib
GXImageBaseImp.lib
GXImageImp.lib
GXImp.lib
InputOutputImp.lib
UCImp.lib
Can you tell me what I am doing wrong pls?
Thanks
Paul
Tibor/Ákos - are you able to provide a response to the issue above pls? I cannot release an AC18 version of my plugin without a resolution to this issue.
Thanks
Paul
