2025-06-12 10:53 PM
Hi Everyone!
I'm experimenting with the ACAPI_Attribute_GetAttributesFromProject function. And I'm getting strange results, I want to ask you what am I doing wrong?
Here's the code I'm trying to run:
GSErrCode err = NoError;
for (GS::USize i = 0; i < fileLocs.GetSize(); i++)
for (GS::USize j = 0; j < attrTypes.GetSize(); j++)
GS::Array<GS::Pair<API_Attribute, API_AttributeDefExt>> resultArray;
err = ACAPI_Attribute_GetAttributesFromProject(fileLocs[i], attrTypes[j], &resultArray);
if (err == NoError)
ACAPI_WriteReport("Found " + GS::ValueToUniString(resultArray.GetSize()) + " " + AttrTypeToString(attrTypes[j]) + " attrubites in external file", true);
else
ACAPI_WriteReport("Error: " + GS::ValueToUniString(err), true);
}I'm building it with the API Development Kit 26.3000. The function returns with err == NoError.
My first attempt was to see if the function works to check the size of resultArray, which I assume should be equal to the number of attributes belonging to each type.
My problem is that resultArray reports size = 0 with some attribute types (Pen, Layer, Material, Font, DimStandards, ModelViewOptions, MEPSystem, BuildingMaterial) although there are many attributes of each type in the file.
With the other attribute types the size of resultArray is as expected.
What am I doing wrong? Does this function not work with all attribute types?
Any help is appreciated!
2025-06-17 11:21 AM
Checked with Dev Kit 28 too.
Very similar result.
The resultArray reports size = 0 with attributes: Layer, Material, MEPSystem and BuildingMaterial attribute types.
3 weeks ago - last edited 3 weeks ago
Hi Ferenc,
Thanks for reporting this, it turned out to be an API bug for those types which are actually treated as attributes in the API (DimStand, MVO are not).
Best, Akos
