Archicad C++ API
ACAPI_Element_Create won't work - help
zaza95
Hello, I'm pretty new to archicad api coding.
I'm trying to do what I think to be a very simple task, create an object via api. I'm doing a sample code that should create an object in coordinates (0,0).
I'm using an object that is already part of default archicad library (Culla.gsm for italian archicad). Could someone help me find what I'm doing wrong?
I want also to say that, for now, I'm using a DEMO version of Archicad, please tell me if this could also be the cause of the issue. I've been using archicad v28 and api dev kit 28.2000.
When I run the add-on,  I get error code -2130313112 when calling ACAPI_Element_Create. This is the case without memo. If I use memo and call ACAPI_Element_Create with memo archicad crashes. (now the screenshots are with memo)
I'm pasting the code I wrote:
GSErrCode PlaceObjectAtOrigin() {
        API_Element element;
        BNZeroMemory(&element, sizeof(API_Element));
        element.header.type = API_ObjectID;
        element.header.floorInd = 0;
        element.object.pos.x = 0.0;
        element.object.pos.y = 0.0;
        element.header.layer = ACAPI_CreateAttributeIndex(1);
        API_LibPart libPart;
        BNZeroMemory(&libPart, sizeof(API_LibPart));
        Int32 libPartCount;
        GS::UniString libPartName("Culla");
        const GS::uchar_t* libPartNameUChar = libPartName.ToUStr();  // Convert to uchar_t*
        size_t nameLength = libPartName.GetLength();                 // Get length of the string
        memcpy(libPart.docu_UName, libPartNameUChar, nameLength * sizeof(GS::uchar_t));// Copy the string to libPart.docu_UName using memcpy
        libPart.docu_UName[nameLength] = '\0';  // Null-terminate the string
        ACAPI_WriteReport("trying to assign default elements'", true);
        GSErrCode m_err = ACAPI_Element_GetDefaults(&element, NULL);
        ACAPI_WriteReport("assigned default elements'", true);
        Int32 m_ParamsCount = 0;
        double a, b;
        API_AddParType** params = NULL;
        m_err = ACAPI_LibraryPart_GetParams(libPart.index, &a, &b, &m_ParamsCount, &params);
        API_ElementMemo* m_memo;
        BNZeroMemory(&m_memo, sizeof(API_ElementMemo));
        m_memo->params = params;
        m_err = ACAPI_LibraryPart_Search(&libPart, false, false);      // Check if the library part was found
        if (m_err == NoError) {
            element.object.libInd = libPart.index;  // Set the object's library index
            ACAPI_WriteReport("library obj found and index assigned - culla", true);
        else {
            ACAPI_WriteReport("Error: Could not find the library part 'Culla'", true);
            ACAPI_WriteReport((std::string("Error code: ") + std::to_string(m_err)).c_str(), true);
            return m_err;
        // Place the object
        GSErrCode err_place = ACAPI_CallUndoableCommand("Place object", [&]() -> GSErrCode {
             return ACAPI_Element_Create(&element, m_memo);  //m_memo or null
        if (err_place != NoError) {
            ACAPI_WriteReport((std::string("Error code: ") + std::to_string(err_place)).c_str(), true);
        return err_place;
Thanks in advance
LChen
Hi, I modified your code. Please try the following one to see whether it works:
HTH.
	Int32 libPartCount;
	GS::UniString libPartName(L("Culla"));
	API_ElementMemo m_memo{};
	GSErrCode m_err = ACAPI_Element_GetDefaults(&element, &m_memo);
		double a, b;
		m_memo.params = params;
	else {
		return m_err;
	// Place the object
			return ACAPI_Element_Create(&element, &m_memo);  //m_memo or null
	ACAPI_DisposeElemMemoHdls(&m_memo);
	return err_place;
1 REPLY 1
LChen
HTH.
	Int32 libPartCount;
		double a, b;
	else {
		return m_err;
	// Place the object
	return err_place;
