Archicad C++ API
ACAPI_GetPreferences how to get its data?
Newbie
I am stuck on getting return data of the above function with below sample code;
Int32 version;
GSSize nBytes;
GSPtr pref;
ACAPI_GetPreferences (&version, &nBytes, nullptr);
if (version == MY_PREFERENCES_VERSION) {
pref = BMAllocatePtr (nBytes, ALLOCATE_CLEAR, 0);
if (pref != nullptr) {
ACAPI_GetPreferences (&version, &nBytes, pref);
// do something with the preferences data
BMKillPtr (&pref); // dispose allocated pointer
Is there anyone know how to convert "pref" to readable text?
Joel Buehler
Short Question: Did you fill in your Data before? That function is for storing your own data, with your own datastructure:
Hello Joel,
I already set the preference data according to its suggestion doc but still can't retrieve it back since the last parameter of get API is GSPtr which do not know how to convert it readable character. Do you have any idea?
Thanks.
kovacsv
Here you can find a detailed explanation of preferences handling:
https://archicadapi.graphisoft.com/archicad-maze-generator-add-on-tutorial-part-3
