2018-12-06 03:21 AM - last edited on 2022-10-04 04:51 PM by Daniel Kassai
Severity Code Description Project File Line Suppression Statecode for Database_Control.cpp file
Warning C4189 'aaaa': local variable is initialized but not referenced Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Examples\Database_Control\Src\Database_Control.cpp 1458
Error (active) E0028 expression must have a constant value Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 62
Error (active) E0145 member "GS::GSException::AlignOfUniString" may not be initialized Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 56
Error (active) E0145 member "GS::GSException::SizeOfUniString" may not be initialized Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Support\Modules\GSRoot\GSException.hpp 57
Error C2220 warning treated as error - no 'object' file generated Database_Control C:\Program Files\Graphisoft\API Development Kit 22.3004\Examples\Database_Control\Src\Database_Control.cpp 1458
static void Do_ExportWallsToExcel (void) { DBPrintf ("Exporting walls to Excel document...\n"); libxl::Book* book = xlCreateXMLBook (); libxl::Sheet* sheet = book->addSheet (UNISTR_TO_LIBXLSTR (GS::UniString("Walls exported from Archicad"))); libxl::Font* guidFormatFont = book->addFont (); guidFormatFont->setSize (6); guidFormatFont->setColor (libxl::COLOR_GRAY50); libxl::Format* guidFormat = book->addFormat (); guidFormat->setFont (guidFormatFont); GS::Array<GS::UniString> titles; titles.Push ("GUID"); titles.Push ("Height"); titles.Push ("BeginCoordX"); titles.Push ("BeginCoordY"); titles.Push ("EndCoordX"); titles.Push ("EndCoordY"); for (UIndex i = 0; i < titles.GetSize (); ++i) { sheet->writeStr (0, i, UNISTR_TO_LIBXLSTR (titles)); } GS::Array<API_Guid> apiguids; ACAPI_Element_GetElemList (API_WallID, &apiguids); for (UIndex i = 0; i < apiguids.GetSize (); ++i) { GS::Guid gsguid = APIGuid2GSGuid (apiguids); API_Element element = {}; element.header.guid = apiguids; GSErrCode err = ACAPI_Element_Get (&element); if (err != NoError) { DBPrintf ("ACAPI_Element_Get returned error (%d) for GUID '%s'\n", err, gsguid.ToUniString ().ToCStr ().Get ()); continue; } API_WallType& wall = element.wall; //DBPrintf ("GUID '%s'\n", gsguid.ToUniString ().ToCStr ().Get ()); sheet->writeStr (i + 1, 0, UNISTR_TO_LIBXLSTR (gsguid.ToUniString ()), guidFormat); sheet->writeNum (i + 1, 1, wall.height); sheet->writeNum (i + 1, 2, wall.begC.x); sheet->writeNum (i + 1, 3, wall.begC.y); sheet->writeNum (i + 1, 4, wall.endC.x); sheet->writeNum (i + 1, 5, wall.endC.y); } IO::Location location; IO::fileSystem.GetSpecialLocation (IO::FileSystem::UserDocuments, &location); location.AppendToLocal (IO::Name ("export.xlsx")); GS::UniString filepath; location.ToPath (&filepath); DBASSERT (book->save (UNISTR_TO_LIBXLSTR(filepath))); book->release (); DBPrintf ("Export operation finished\n"); }code for GSException.hpp file
// ***************************************************************************** // // Class GSException // // Module: GSRoot // Namespace: GS // Contact person: MB, FGY, MM // // SG compatible // // ***************************************************************************** #ifndef GSEXCEPTION_HPP #define GSEXCEPTION_HPP #pragma once #include <stdio.h> #include <exception> #include <new> #include "GSRootExport.hpp" #include "Definitions.hpp" #include "GSDebug.hpp" namespace GS { class ClassInfo; } namespace GS { class OChannel; } namespace GS { class UniString; } #include "StackInfo.hpp" // Undefine Windows Macros, we want to use "GetMessage" #if defined (WINDOWS) #if defined (GetMessage) #undef GetMessage #endif #endif // ============================== Class GSException ============================== #define GS_EXCEPTIONS_DLL_EXPORTED namespace GS { #define GS_EXCEPTIONS_INLINE #define GS_EXCEPTIONS_GSROOT_DLL_EXPORT GSROOT_DLL_EXPORT class GSROOT_DLL_EXPORT GSException { // DECLARE_DYNAMIC_CLASS public: typedef StackInfoCustomDepth<128> StackInfo; private: static constexpr USize AlignOfUniString = alignof (void*); static constexpr USize SizeOfUniString = 2 * sizeof (void*); Int32 id; // this is the equivalent error id (it is the same for the given type of exception) GS::UniString& message; // additional message for the exception from the thrower (if it isn't nullptr) alignas (AlignOfUniString) char messageStorage[SizeOfUniString]; const char* fileName; // name of file where the exception was thrown from (if it isn't nullptr) UInt32 lineNumber; // line number where the exception was thrown from (if it isn't 0) GSException* cause; // exception chaining GSException::StackInfo stackInfo; void SetCause (const GSException* cause); void SetCause (const GSException& cause); public: // Constructors explicit GSException (const char* message = nullptr, const char* fileName = nullptr, UInt32 lineNumber = 0, const GSException* cause = nullptr, Int32 id = 0 // should be wired in all of the derived classes ); explicit GSException (const char* message, const char* fileName, UInt32 lineNumber, const GSException& cause, Int32 id // should be wired in all of the derived classes ); explicit GSException (const GS::UniString& message, const char* fileName = nullptr, UInt32 lineNumber = 0, const GSException* cause = nullptr, Int32 id = 0 // should be wired in all of the derived classes ); explicit GSException ( const GS::UniString& message, const char* fileName, UInt32 lineNumber, const GSException& cause, Int32 id // should be wired in all of the derived classes ); GSException (const GSException& source); virtual ~GSException () throw (); // User interface void SetMessage (const GS::UniString& message); void SetMessage (const char* message); virtual const char* GetName (void) const; virtual Int32 GetID (void) const; virtual const GS::UniString& GetMessage (void) const; virtual const char* GetFileName (void) const; virtual UInt32 GetLineNumber (void) const; virtual GSException* Clone (void) const; virtual void Print (OChannel& oc) const; virtual void Dump (OChannel& oc) const; virtual const GSException* GetCause () const; virtual GSException* GetCause (); virtual const StackInfo& GetStack () const; GSException& operator= (const GSException& source); }; extern const GSROOT_DLL_EXPORT GSException NoCauseException; // Special value used when there's no cause of the exception typedef GSException Exception; // GS::Exception // ______________________________ Class GSException ______________________________ // ======================= GSException hierarchy framework ======================= class GS_EXCEPTIONS_GSROOT_DLL_EXPORT RootException : virtual public GSException { public: explicit RootException (const char* msg, const char* fName, UInt32 lNumber, const GSException& cause_) : GSException (msg, fName, lNumber, cause_, (Int32)Error) {} explicit RootException (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0) : GSException (msg, fName, lNumber, nullptr, (Int32)Error) {} explicit RootException (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GSException& cause_) : GSException (msg, fName, lNumber, cause_, (Int32)Error) {} explicit RootException (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0) : GSException (msg, fName, lNumber, nullptr, (Int32)Error) {} virtual const char* GetName () const override; virtual GSException* Clone (void) const override; }; class GS_EXCEPTIONS_GSROOT_DLL_EXPORT GeneralException : virtual public GSException { public: explicit GeneralException (const char* msg, const char* fName, UInt32 lNumber, const GSException& cause_) : GSException (msg, fName, lNumber, cause_, (Int32)Error) {} explicit GeneralException (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0) : GSException (msg, fName, lNumber, nullptr, (Int32)Error) {} explicit GeneralException (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GSException& cause_) : GSException (msg, fName, lNumber, cause_, (Int32)Error) {} explicit GeneralException (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0) : GSException (msg, fName, lNumber, nullptr, (Int32)Error) {} virtual const char* GetName () const override; virtual GSException* Clone (void) const override; }; #define DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(classSpec, className, baseClassName, errId) \ class classSpec: virtual public baseClassName { \ public: \ explicit className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \ explicit className (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0); \ explicit className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \ explicit className (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0); \ virtual const char* GetName () const override; \ virtual GS::GSException* Clone (void) const override; \ }; #define DECLARE_EXCEPTION_CLASS(className, baseClassName, errId, exportdef) \ DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(exportdef className, className, baseClassName, errId) #define DECLARE_EXCEPTION_CLASS_NO_EXPORTDEF(className, baseClassName, errId) \ DECLARE_EXCEPTION_CLASS_WITH_CLASS_SPEC(className, className, baseClassName, errId) #define IMPLEMENT_EXCEPTION_CLASS_WITH_NAMESPACE(classNameWithNamespace, className, baseClassName, errId) \ classNameWithNamespace::className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \ GS::GSException (msg, fName, lNumber, cause, errId), baseClassName () {} \ classNameWithNamespace::className (const char* msg, const char* fName, UInt32 lNumber): \ GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName () {} \ classNameWithNamespace::className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \ GS::GSException (msg, fName, lNumber, cause, errId), baseClassName () {} \ classNameWithNamespace::className (const GS::UniString& msg, const char* fName, UInt32 lNumber): \ GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName () {} \ const char* classNameWithNamespace::GetName () const { return #className; } \ GS::GSException* classNameWithNamespace::Clone (void) const { return new className (*this); } #define IMPLEMENT_EXCEPTION_CLASS(className, baseClassName, errId) \ IMPLEMENT_EXCEPTION_CLASS_WITH_NAMESPACE (className, className, baseClassName, errId) #define DECLARE_EXCEPTION_CLASS2(className, baseClassName1, baseClassName2, errId, exportdef) \ class exportdef className: virtual public baseClassName1, virtual public baseClassName2 { \ public: \ explicit className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \ explicit className (const char* msg = nullptr, const char* fName = nullptr, UInt32 lNumber = 0); \ explicit className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause); \ explicit className (const GS::UniString& msg, const char* fName = nullptr, UInt32 lNumber = 0); \ virtual const char* GetName () const override; \ virtual GS::GSException* Clone (void) const override; \ }; #define IMPLEMENT_EXCEPTION_CLASS2(className, baseClassName1, baseClassName2, errId) \ className::className (const char* msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \ GS::GSException (msg, fName, lNumber, cause, errId), baseClassName1 (), baseClassName2 () {} \ className::className (const char* msg, const char* fName, UInt32 lNumber): \ GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName1 (), baseClassName2 () {} \ className::className (const GS::UniString& msg, const char* fName, UInt32 lNumber, const GS::GSException& cause): \ GS::GSException (msg, fName, lNumber, cause, errId), baseClassName1 (), baseClassName2 () {} \ className::className (const GS::UniString& msg, const char* fName, UInt32 lNumber): \ GS::GSException (msg, fName, lNumber, nullptr, errId), baseClassName1 (), baseClassName2 () {} \ const char* className::GetName () const { return #className; } \ GS::GSException* className::Clone (void) const { return new className (*this); } DECLARE_EXCEPTION_CLASS (LogicErrorException, GeneralException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (PreconditionException, LogicErrorException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (IllegalArgumentException, PreconditionException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (IllegalReferenceException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (NullPointerException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (NullReferenceException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (NullHandleException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (EmptyHandleException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (IllegalTypeException, IllegalArgumentException, ErrParam, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (RunTimeErrorException, GeneralException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (AccessViolationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (LimitViolationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (ConversionErrorException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (InternalErrorException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (IllegalStateException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS (UnsupportedOperationException, RunTimeErrorException, Error, GSROOT_DLL_EXPORT) DECLARE_EXCEPTION_CLASS2 (OutOfMemoryException, RunTimeErrorException, std::bad_alloc, ErrMemoryFull, GSROOT_DLL_EXPORT) // General implementation of the precondition #define PRECOND_IMP(preCondition, exception) \ if (!(preCondition)) { \ DBBREAK (); \ throw exception (nullptr, __FILE__, __LINE__); \ } // Preconditions that will be compiled only into the debug and test versions #define PRECOND(condition) DBASSERT(condition) #define ARG_CHECK(condition) DBASSERT(condition) #define REF_CHECK(condition) DBASSERT(condition) #define NULL_PTR_CHECK(ptr) DBASSERT(ptr != nullptr) #define NULL_REF_CHECK(ref) DBASSERT(&ref != nullptr) #define TYPE_CHECK(condition) DBASSERT(condition) // Preconditions that will always be compiled (debug, test and release) #define PRECOND_R(condition) PRECOND_IMP(condition, GS::PreconditionException) #define ARG_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalArgumentException) #define REF_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalReferenceException) #define NULL_PTR_CHECK_R(ptr) PRECOND_IMP(ptr != nullptr, GS::NullPointerException) #define NULL_REF_CHECK_R(ref) PRECOND_IMP(&ref != nullptr, GS::NullReferenceException) #define TYPE_CHECK_R(condition) PRECOND_IMP(condition, GS::IllegalTypeException) // _______________________ GSException hierarchy framework _______________________ } #endif
Solved! Go to Solution.
2018-12-15 10:01 AM
2018-12-06 10:40 AM
2018-12-07 03:55 PM
2018-12-15 10:01 AM
2018-12-17 02:35 AM
2018-12-20 08:18 AM
