Learn more
API_Gable(Plane coefficients)
Could you please explain the plane coefficients
a, b, c, d - Plane coefficients relative to the parent element.
What is parent element and where is its origin? I mean in which coordinate system the plane is specified.
See GS.APIDevKit.1033/APIDoc/APIHTMLLibrary/Structures/API_Gable.html
2 Replies 2
Oleg
I never used it therefore I can guess only.
I hope somebody from GS will state it more definitely.
I think a parent element is the cutted element which contains gables array (handle) in the API_ElementMemo structure ( wall, column, object etc ).
And the plane equation coefficients are relative the local coordinate system of this element.
Otherwise I think it would be required to recalculate coefficients at every moving or rotation of the element.
I have used this when getting the planes that represent the top of the wall after it is cut to roof.
To get a point on the plane use this formula:
ax + by +cz + d = 0
ie. plug in x and y and you will get the z value at that coordinate, etc.
