Archicad C++ API
API: How to create Rectangle Column?
Yeojin
Hi Everyone.
I practice to create Add-On that create rectangle columns but its doesn't work to control core width / height and structure.
I already try this post solution but it's not working to me.
https://community.Graphisoft.com/t5/Developer-forum/AC24-how-to-change-rectangle-columns-section-wid...
I'd like to write a column that modified the parameters I marked.
How can I modify the code?
column.column.origoPos.x = data.begX;
column.column.origoPos.y = data.begY;
column.column.relativeTopStory = 0;
column.columnSegment.assemblySegmentData.circleBased = 0;	//rectangular(=false)
column.columnSegment.assemblySegmentData.isWidthAndHeightLinked = 0; // false
column.columnSegment.assemblySegmentData.nominalWidth = data.height;	//Nominal width of segment.
column.columnSegment.assemblySegmentData.nominalHeight = data.level;	//Normal height of segment.
Hi Yeojin,
There a few details wrong in the code you provided. Here's an example on how I would fix it:
columnElement.column.origoPos.x = data.begX;
columnElement.column.origoPos.y = data.begY;
columnElement.column.bottomOffset = 2; // this is the column base level in meters relative to it's floor
columnMemo.columnSegments[0].assemblySegmentData.circleBased = 0;	//rectangular(=false)
columnMemo.columnSegments[0].assemblySegmentData.isWidthAndHeightLinked = 0; // false
columnMemo.columnSegments[0].assemblySegmentData.nominalWidth = data.height;	//Nominal width of segment.
columnMemo.columnSegments[0].assemblySegmentData.nominalHeight = data.level;	//Normal height of segment.
 It's important to differentiate between the element and the element memo! Also you have to specify the width/weight for a specific column Segment. In the code above i used columnSegments[0]. You would have to adjust the code if the column has more than one segment.
`columnElement.column.bottomOffset` corresponds to the lower marks in your first picture.
Hope that helps,
Bernd
Hi Yeojin,
Hope that helps,
Bernd
Hi Bernd
Thank you so much! 😄 it works!
