2024-09-29
04:43 PM
- last edited on
2024-10-01
09:03 PM
by
Hello friends
I created a precast column with GDL. Archicad sees it as an object, not as a column, because it is made via GDL.
Normally when a column passes through a slab, Archicad creates a gap in the slab according to the order of priority, but when it comes to an object, I have to create all these gaps manually in order not to get a conflict error. Is there any way to automatically cut objects as well?
Sorry, my English is not very good.
Thank you
2024-09-30 02:51 AM
Objects do not take part in automatic Priority Based Connections.
You must perform a Solid Element Operation.
However that column could be created as a segmented column, and if complex profiles are used for the segments, they can also have profile modifiers that can allow for some on screen adjustments.
2024-09-30 06:06 AM - edited 2024-09-30 06:07 AM
Thanks @Barry Kelly
But this is a simple version of column. There's no way I can do this with the column tool. I guess I have to SEO the model every time.
2024-09-30 07:12 AM
You can do some pretty amazing columns with a segmented column.
2024-09-30 08:29 AM
Which version of AC are you using?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2024-09-30 09:03 AM
Archicad segmented columns are great, but the real trick of this column is the oblique consoles. Firstly, I tried to do this by creating a custom profile, but I could not find a way to create oblique consoles that are not symmetrical or overlapping at close heights. So I created an object via gdl.
2024-09-30 09:06 AM
27
2024-09-30 10:00 AM
That would be difficult, as you would need overlapping segments for the different console heights.
GDL is a good way to go.
