Archicad C++ API
APIERR_MEMFULL LibPart_Register
IO::Location     fileLoc ("C:\\temp\\MyLibpart.gsm");
API_LibPart      libPart;
GSErrCode        err;
BNZeroMemory (&libPart, sizeof (API_LibPart));
libPart.typeID   = APILib_ObjectID;
libPart.location = &fileLoc;
err = ACAPI_LibPart_Register (&libPart);
Any ideas why i'm getting MEMFULL error ?
Akos Somorjai
GSErrCode        err;
I agree that this is a misleading error. The problem is that you are trying to register a library part which is not in the embedded library.
Best, Akos
Thanks Akos!
I was trying to add library part to embedded library.
I guess only way would be to make new one through creating new one.
Akos Somorjai
Rinovo wrote:
Thanks Akos!
Yeah, you can create one directly in the embedded library:
	IO::Location file;
	GS::UniString str;
	GetIndString (str, 32552, 1);  // default name
	ACAPI_Interface (APIIo_GetLastValidEmbeddedLPNameID, &str, &file);
	// Save As dialog
	bool bff = false;
	bool retIsOk;
	ACAPI_Interface (APIIo_SaveLibPartFileDialogID, &retIsOk, &file, &bff, &str);
	if (retIsOk) {
		// Create the libpart
		CreateLibpart (libPart, file);
You can skip the save dialog, just use the location from the APIIo_GetLastValidEmbeddedLPNameID call (but don't forget to replace the last local name).
Best, Akos
